December 18th, 2021 10:20 PM #1
- 5,509
How to Customize StartAllBack++ , Icons , Start Orbs , Details Pane .etc
StartAllBack++ for Windows 11 21h2++
how to move Details Pane on Top (TopShell)
how to move Details Pane on Bottom (BottomShell)
https://virtualcustoms.net/OldNewExplorer-TopShell-and-BottomShell-Right-and-Left-side-8-versions-for-Windows-11
StartAllBack use this new changes ported and included from OldNewExplorer
if you like some of this changes then can be all edited manually in the
StartAllBack64.cfg UIFILE DETAILS
UIFILE 3, 4, 5, 6, 19, 20, 21
and in the
StartAllBackA64.cfg UIFILE DETAILS
how to change StartAllBack Icon
go to C:\Users\*your username*\AppData\Local\StartAllBack
or go to C:\program files\StartAllBack
and open StartAllBackCfg with Restorator or with resource hacker
Default StartAllBack Icon you can find as
StartAllBackCfg\Icon\MAINICON
how to change StartAllBack Blur and Clear Icons
Default StartAllBack Blur and Clear Icons you can find as
StartAllBackCfg\Icon\ZBLURMORE
StartAllBackCfg\Icon\ZBLURMOST
StartAllBackCfg\Icon\ZBLUROFF
StartAllBackCfg\Icon\ZBLURON
how to change , add or remove StartAllBack Start Orbsexist more way how toopen StartAllBackCfg\Taskbar and click on +add your Start Orb supported images is PNG and bmphow to change , add or remove StartAllBack Start Orbs manuallygo to C:\Users\*your username*\AppData\Local\StartAllBack\Orbsor go to C:\program files\StartAllBack\Orbscopy or remove Start Orbs from this directory
how to replace StartAllBack Start Orbs permanently
go to C:\Users\*your username*\AppData\Local\StartAllBack\Orbsor go to C:\program files\StartAllBack\Orbsopen file Windows 7.orb with Restorator or with resource hackerDefault StartAllBack Start Orbs you can find asWindows 7.orb\Bitmap\6805Windows 7.orb\Bitmap\6806Windows 7.orb\Bitmap\6807Windows 7.orb\Bitmap\6808
how to replace Start Orb permanently in the theme .msstyle file
open your theme .msstyle with Restorator
and replace default Start Orb
.msstyle file\IMAGE\956
if someone do not have Restorator
then can replace default Start Orb with Windows Style Builder here
Taskbar & System Tray > TaskBar > Aero > Start Button > Small Icons Start Button
Taskbar & System Tray > TaskBar > Aero > Start Button > Small Icons Start Button > Normal
Taskbar & System Tray > TaskBar > Aero > Start Button > Small Icons Start Button > Hot
Taskbar & System Tray > TaskBar > Aero > Start Button > Small Icons Start Button > Pressed
Taskbar & System Tray > TaskBar > Aero > Start Button > Large Icons Start Button
Taskbar & System Tray > TaskBar > Aero > Start Button > Large Icons Start Button > Normal
Taskbar & System Tray > TaskBar > Aero > Start Button > Large Icons Start Button > Hot
Taskbar & System Tray > TaskBar > Aero > Start Button > Large Icons Start Button > Pressed
hope this help to you my Friends
How to Customize StartIsBack , Icons , Start Orbs , default User pic frame .etc
By ミறѳѳղղįզվદ彡 in forum Moonnique's Ported ThemesReplies: 8Last Post: June 20th, 2024, 04:03 PM -
Shell32 Details Pane Mod for Windows 8.1 Only!!
By Mr GRiM in forum Customization ToolsReplies: 14Last Post: September 25th, 2019, 01:23 AM -
How to move the details pane at the top in Windows Explorer ?
By ceo54 in forum Windows 8 & 8.1 Theme Help & SupportReplies: 10Last Post: September 3rd, 2019, 06:42 AM -
How Do I Hide Details Pane at Bottom of Win Explorer??
By koolx in forum Windows 10 Theme Help and SupportReplies: 0Last Post: May 20th, 2018, 10:30 AM -
Bottom Details Pane for Windows 8
By Mr GRiM in forum Customization ToolsReplies: 9Last Post: July 20th, 2013, 08:55 AM
then it may be that your system uses locked files sometimes it also happens when using the ultrauxthemepatcher application the only way is to take ownership ExplorerFrame.dll.mun file manually...
Animation in explorer...
