Results 1 to 6 of 46
Thread: MSI Dragon Red Ultimate Theme edition for Windows 10 19h1-21h2 8K
    ミறѳѳղղįզվદ彡 is offline
    🌸In the Future🌸
    5,516
    Package Favorite MSI Dragon Red Ultimate Theme edition for Windows 10 19h1-21h2 8K
    Mr GRiM and Razorsedge
    Alienbyte
    ✧☣ ДŁƗɆȠƁƳƬЄ™☣✧
    Jose Pedro Flores and DShepe
    Villi Vidi Vici®
    and Moonnique®
    MSI Dragon Red Ultimate edition for Windows 10
    Windows 10 19h1 19h2 20h1 20h2 21h1 21h2
    Merry Christmas and Happy New Year!
    Video preview and images has been created on
    Windows 11 21h2 OS Build 22000
    theme with all other Extras can be used only on
    Support for Ultimate Desktops 4K 5K 8K with DPI Scaling up to 100% - 200%
    4K 5K 8K monitors need using Supported themes with DPI scaling up to 100% - 200%
    Fully replaced and Customized
    Personalize (Classic) Context Menu
    7tsp MSI Dragon Red Icon Pack for Windows 10
    7tsp MSI Dragon Red MUI Side Images for Windows 10
    ported for Windows 10 19h1-21h2 by
    Moonnique®
    7tsp Icon Pack for Windows 10 19h1-21h2
    This Icon Pack and MUI Side Images has been created only for Windows 10
    with new .mun files located in the
    C:\Windows\SystemResources directory
    Ultimate Icon Pack includes 81 .res files
    7tsp MSI Dragon Red
    Theme for Restorator 2007-2018
    Thread has been updated
    7tsp MSI Dragon Red Ultimate Icon Pack w10 19h1-21h2 has been updated
    has been created a new basebrd.dll (About Windows) file for Windows 10 users
    Windows 11 use a different basebrd.dll file as Windows 10
    hello friends thread has been again updated
    has been created and added theme version 2 with different taskbar
    now you can use version 1 or version 2 just what you like
    if have someone problem with start menu and with username
    just open StartIsBack and Uncheck Hide user account picture
    thank you for all likes nice comments and downloads my friends
    this is my last post in this year see you in New Year 2022 stay safe
    Some of the other Extras created by me
    7tsp Red Address Bar Icons for w10 19h1-21h2
    https://virtualcustoms.net/7tsp-Address-Bar-Icons-for-w10-19h1-21h2-and-for-w11-21h2-by-Moonnique®
    7tsp Allow all Theme Extras Permanently w10 19h1-21h2
    https://virtualcustoms.net/Windows-10-21h1-updated-shell-7tsp-Allow-all-Theme-Extras-Permanently
    7tsp Elegant Red Theme Frames and Icons for w10 19h1-21h2
    https://virtualcustoms.net/Elegant-Blue-and-Dark-Red-Theme-Frames-and-Icons-for-w10-19h1-21h2-Windows-11
    StartIsBack++ v2.9.17 Theme and Font Color fix by Moonnique®
    https://virtualcustoms.net/StartIsBack-Theme-and-Font-Color-fix-by-Moonnique®
    OldNewExplorer TopShell and BottomShell Right and Left side 8 versions for w10 19h1-21h2
    https://virtualcustoms.net/OldNewExplorer-TopShell-and-BottomShell-Right-and-Left-side-8-versions-for-w10-w11
    Click on Start Patching.
    7tsp Icon Pack for Windows 10 19h1 - 21h2
  1. HUD Machine Red Ultimate edition for Windows 10 19h1 19h2 20h1 20h2 21h1 21h2
    Last Post: April 4th, 2023, 03:52 PM
  2. Raya and the Last Dragon Ultimate Theme edition for Windows 10 19h1-21h2
    Last Post: December 19th, 2022, 12:08 PM
  3. Nemesis Ultimate theme edition for Windows 10 19h1 19h2 20h1 20h2 21h1 21h2
    Last Post: December 7th, 2022, 09:48 AM
  4. Blade v2 Ultimate edition for Windows 10 19h1 19h2 20h1 20h2 21h1 21h2
    Last Post: July 30th, 2021, 02:41 PM
  5. M-CLASS Ultimate edition for Windows 10 19h1 19h2 20h1 20h2 21h1 21h2
    Last Post: July 11th, 2021, 09:25 AM
