June 22nd, 2023 09:42 AM #2
- Nov 2017
- Australia
- 1,328
- 11 Thread(s)
Hi Nierewa. Welcome to VC Mate, OK now if your using a Custom Theme in Dark Mode it will always show that grey hover effect. Try using Light Mode and see if it stops. Its a glitch we cant do anything about but you can also use the Start orb that should be in the Theme Folder with the msstyles called explorer.exe and select it from there
Just right click the orb to pop the menu up and select Properties to open StartisBack Configurations, then on the right hand side under the orbs select add with the green cross.
Select your orb and then click apply back in the Configurations.
This method is much better and will show the orb normal when you hover over it.
Windows 10 Open/Save Dialog Box and StartButton Issues
By jwilco in forum Windows 10 Theme Help and SupportReplies: 4Last Post: January 11th, 2016, 11:08 PM -
Taskbar icons color hover
By nelly80 in forum Taskbar & System TrayReplies: 2Last Post: February 4th, 2011, 03:52 AM -
Need some help with WSB 1.5 - explorer hover images?
By TheAslan in forum Windows and caption buttonsReplies: 2Last Post: December 9th, 2010, 12:56 PM -
Longhorn Startbutton
By dafmat71 in forum Start Buttons/OrbsReplies: 0Last Post: September 23rd, 2010, 12:29 PM -
[Win7/Vista] Dock users - hide Taskbar & Startbutton 100%
By Generator2013 in forum TaskbarReplies: 5Last Post: April 26th, 2010, 11:36 PM
foobar2000 v2.1.5 Dark...
