July 4th, 2023 02:05 AM #1
Windows 7 import to Windows 11 22H2
Important, do not use this to update any themes newer then Windows 7 , for newer themes go here Windows 11 22H2 Updated ClassMaps and Import Scripts
This update allows you to update themes from Windows 7 to the latest Windows 11 22H2.
Update your theme by using the following instructions.
For updating a Windows 7 theme to Windows 11 22H2 first use Windows Style Builder 7-11 Part 1
1. Open the folder called "Windows Style Builder 7-11 Part 1"
2. Open the WSB Program.
3. Go to File > Open > Import 7 Theme and Import the Windows 7 theme you want to update.
4. Save your updated theme, do not test the theme or apply any fix and then proceed to the following steps.
After you have completed the steps for Windows Style Builder 7-11 Part 1
1. Open the folder called "Windows Style Builder 7-11 Part 2"
4. Select Import Style Hack and select "Windows 11 DWM Import Fix" (Very important!!, do not miss this step!!)
If you are on Windows 10 then you can also do the same step but selecting "Windows 10 DWM Import Fix"
5. Save your theme and then reopen it again, then save it once more.
6.You can now test your Theme and make sure it has imported correctly and does not give you any msstyles errors.
Enjoy
NOTEDon't forget to replace the shell folder with the updated one, if you are going to save the updated theme in the same folder then replace the shell folder before you update the theme.
InformationYou can use this version to update your Windows 7 themes on Windows 10 by following the same steps, the themes will still work fine on Windows 11 but they will not have any window animations.
InformationAdded new Shellstyle.dll to this release as last one had an issue displaying small icons.
WARNINGDisclaimer, I am not responsible for any one trying out these scripts or for anyone who bricks their system, these are experimental and should be used on a Virtual machine for your safety. Last edited by Mr GRiM; July 4th, 2023 at 02:09 AM.
By Mr GRiM in forum Updates & Style Hacks For WSBReplies: 177Last Post: June 16th, 2024, 10:22 PM -
By Mr GRiM in forum Updates & Style Hacks For WSBReplies: 15Last Post: July 28th, 2023, 11:18 AM -
Windows 8.1 Theme Import By Your Choice
By Lamia in forum Windows 8 & 8.1 Theme Help & SupportReplies: 26Last Post: April 9th, 2017, 11:33 AM -
Custom Import Scripts Import for Windows 7/8.1?
By Shemhamforash in forum Miscellaneous questionsReplies: 12Last Post: May 9th, 2016, 02:49 PM
Show Us Your Rig
