Thread: Zero-G Pink v2 for Windows 11
September 23rd, 2023 03:01 AM #1
- Aug 2014
- Ontario, Canada
- 1,913
- 167 Thread(s)
Installation Guide
1. Install UltraUxThemePatcher:UltraUxThemePatcher allows you to use custom themes by patching your Windows system files.
2. Prepare the Theme:
Copy the theme to the "C:\Windows\Resources\Themes" directory. Install the fonts. Create a restore point.
3. Customize the Taskbar and Start Menu:
In StartAllBack check the "Win7 command bar" and "Enable details pane on the bottom" options. Apply the skinned start orb.
4. Adjust System Metrics:
Merge the theme's window metrics file with the system metrics settings.
5. Add Personalization to the RC Menu:
Enable "Add personalization to the desktop context menu" in Winaero Tweaker.
6. Reboot:
Restart the computer to ensure all changes take effect.
7. Apply the Custom Theme:
Right-click on the desktop. Choose "Appearance" > "Desktop Background." Navigate to "Personalization" and apply the theme.
8. Customize Control Panel with OldNewExplorer (Optional):
Note that OldNewExplorer can be unstable.
9. Customize Window Frames with BasicThemer (Optional):
Be aware that at higher DPI settings, caption buttons may not appear correctly. This customization does not affect the Modern UI elements; they remain unchanged. For autostart, copy its shortcut to shell:startup.
10. Create a Restore Point:
Create a restore point to safeguard the system configuration.
CreditsOriginal W7 theme design by Mr Grim
Pink Recolor by One Man Army
Import to W11 by J4M3SX019/Shemhamforash
(c) 2023 virtualcustoms.net
I take no responsibility for anyone that bricks their system, use custom themes at your own risk.Last edited by Shemhamforash; November 19th, 2023 at 01:01 AM.
By Shemhamforash in forum Themes by ShemhamforashReplies: 0Last Post: September 23rd, 2023, 03:01 AM -
Zero-G Pink For Windows 11 21h2-23h2++
By Erin in forum Themes by ErinReplies: 0Last Post: September 16th, 2023, 01:21 PM -
Zero-G Pink
By ONE MAN ARMY in forum Mr GRiM's Windows 7 ThemesReplies: 25Last Post: October 8th, 2022, 08:58 AM -
Zero-G 1.0 Windows 8.1.1 Theme
By Lamia in forum Mr GRiM's Windows 8 ThemesReplies: 9Last Post: September 26th, 2015, 10:49 PM -
Sub Zero Sapphire Windows 8.1.1 Theme
By Lamia in forum Razorsedge windows 8 ThemesReplies: 8Last Post: May 11th, 2015, 06:23 PM
The only thing I couldn't get to work with the DWM blur app is the title bar text color. https://github.com/Maplespe/DWMBlurGlass?tab=readme-ov-file
Post Your Windows 11...
