Results 13 to 18 of 18
June 26th, 2024 11:16 AM #13
June 26th, 2024 09:12 PM #14
- Jun 2010
- 176
- 201 Thread(s)
June 26th, 2024 11:25 PM #15
I was sorry, so I spent two hours and all my efforts to fix this problem
I had to do a clean installation of Windows 10 to find out where the problem is because I'm currently using the Windows 12 system
each of my windows systems is always unique, therefore it differs from everyone and it is difficult for me to find a solution
the only way is a clean installation as it was in this case
I found a solution, every theme patcher blocks this function
because the theme patcher activates the shell file in the theme folder
therefore follow my simplest steps
I made a complete updated file for activating all theme Extras
the only thing that needs to be done is to delete the shell file from the theme directory
C:\WINDOWS\Resources\Themes\*current theme*shell - delete this shell folder
run 7tsp GUI as Administrator and use animation what you like
7tsp Allow all Theme Extras Permanently for w10 19h1-22h2++ v1 by Moonnique
or
7tsp Allow all Theme Extras Permanently for w10 19h1-22h2++ v2 by Moonnique
version 1 = animation="rectangle|exp|fast"
version 2 = animation="position|exp|fast"
I hope this will finally solve your problem because it works like a charm on a clean installationLast edited by ミறѳѳղղįզվદ彡; June 26th, 2024 at 11:29 PM.
June 27th, 2024 10:34 AM #16
- Jun 2010
- 176
- 201 Thread(s)
Thank you for your hard work, now it works like it should.
One last question, if one day I'm tired of the animation what should I do ?
In the original files were a backup file, with the new ones not.
June 27th, 2024 11:36 AM #17
I made it as simple as possible
if one day you get tired of animation
just copy the shell file again to the folder where the theme is located
the shell file can be copied from any Windows 10 theme
this disables my added animation
if you want to activate the animation again
simply delete the shell file from the theme folder
no backup or /sfc system scan is now not required for disable
I try to make things as simple as possible
June 27th, 2024 04:13 PM #18
- Jun 2010
- 176
- 201 Thread(s)
I also thought that this would be the solution, so thanks again.
Windows 11 24H2 OS Build 26100
By ミறѳѳղղįզվદ彡 in forum General Windows 11 CustomizationReplies: 0Last Post: May 3rd, 2024, 03:23 PM -
7tsp Molta Bella System Icons (Black & Blue) w10 19h1-22H2++ and w11 21h2++
By ミறѳѳղղįզվદ彡 in forum 7tsp Icon PacksReplies: 2Last Post: January 12th, 2023, 10:11 AM -
How to replace and patch explorer.exe with 7tsp correctly in w10 19h1+ and w11 21h2+
By ミறѳѳղղįզվદ彡 in forum 7tsp Important Themepack FixesReplies: 10Last Post: September 4th, 2022, 06:38 PM -
RemoveAddressBar for Windows 10 19h1-21h2 and for Windows 11 21h2++
By ミறѳѳղղįզվદ彡 in forum General Windows 11 CustomizationReplies: 0Last Post: November 17th, 2021, 02:08 PM -
7tsp Cleaner address bar for Windows 10 19h1-21h2 and for Windows 11 21h2++
By ミறѳѳղղįզվદ彡 in forum Moonnique's Ported ThemesReplies: 0Last Post: November 13th, 2021, 06:21 PM
