July 28th, 2010 11:42 PM #1
Making an Autorun menu for wpi on your custom os
This tutorial will explain how to make a custom autoplay menu for your modded os. So that when u put your os disk in a cd or
dvd drive of a computer that has windows on it already you will get a splash screen to come up where u can just click run wpi
to bring up your wpi post installer
first u will need autoplay media studio
So after u have it installed open autoplay media studio
First thing is to click create new project
Now in the enter project name box pick a name for your project and enter it there
You will see in the box many templates for making your autoplay menu myself I use my own custom pictures for the menu
so I always select blank project here
Your can pick a template if u like any of the ones u see but for this tutorial I will be showing you as per using
blank project
So now just double click blank project
So here we have the blank page, now time to pick your back ground
find the picture u would like to use and just drag and drop it in
Now we will set up the auto play buttons
So at the top click the blue square (new button project)
As u see there are many folders with buttons in different colors
You can choose anyone u like or if u have your own custom buttons or pictures u would like to use just navigate to them and select
Now move the button where u would like it on the menu by just clicking on it and dragging
You can also make the button smaller or bigger here at the same time
Now on the left hand side in the properties box click on text to add text to you button
Ok now we need to add the commands to the button to tell it what to do
So in the properties scroll down to the bottom and under actions click where it says ON CLICK
Ok here you can have one of 2 choices if u want the button to open the wpi as well as exit then u will add 2 commands
to the button these are the commands
Code:File.Open("WPI\\WPI.hta", "", SW_SHOWNORMAL);
Code:Application.Exit(0);
I myself use 2 buttons one for starting the wpi and one for exit so in this cause u would just add the first line to the wpi button
then go back to the top click the blue square again (new button Project)
choose the button u want
back to the left side again click text enter what text u would like
then scroll down to actions again click the action ON CLICK again
and enter this code line
now to create the project
at the top on tabs click publish
from the drop down menu select Build
in this screen put the dot in hard drive folder
(autoplay media studio will have made a folder on install in your my documents folder thats where this will go)
now click next
now click build
now close the application
go to your my documents folder, into the autoplay media studio 7.0 folder
now go into the projects folder and click on the folder with the name of your project
now inside click on the folder named cd root
inside u will see 3 items, autoplay folder, autorun.exe and autorun.inf highlight and copy all 3
you will place all 3 of these at the root of your os
u will be asked when copying to the root of your os would u like to replace the autorun.inf cause this file will exist
yes u want to replace it
that now completes your auto play menu so now when u insert your os disk on a computer that has windows installed
you will be able to run the wpi automatically
Custom Context Menu for Windows 11
By ミறѳѳղղįզվદ彡 in forum General Windows 11 CustomizationReplies: 3Last Post: February 10th, 2022, 04:50 AM -
Need Advice, or help on Skype making custom Win7 usb installer
By YourNumbr1Fan in forum Chill Out RoomReplies: 7Last Post: July 29th, 2013, 01:17 AM -
Making a Custom Start Orb
By Zilla in forum Start OrbsReplies: 3Last Post: June 24th, 2012, 03:59 AM -
I'm new at this, help making start menu transparent using windows 7 style builer 1.5
By Dmugen in forum Windows Style Builder v1.5 TutorialsReplies: 0Last Post: June 16th, 2012, 09:27 PM -
Custom Start Menu Questions
By Species A.I. in forum Start MenuReplies: 2Last Post: February 12th, 2011, 03:46 AM
Wow , I can no longer support Microsoft's shady moves , after Windows 10 end of life it is on to Linux for me, I already have it on my laptop. Microsoft is in for a rude awakening at Windows 10...
