Results 1 to 6 of 21
Thread: Blade v2 by Mr GRiM
November 11th, 2018 07:54 AM #1
- 5,505
Blade v2 by Mr GRiM
Mr GRiM
Blade v1 taskbar
Blade v2 taskbar
Blade v2 taskbar
Blade v2 for Windows 10 1703 , 1709 and 1803
Blade v2 for Windows 10 1809 ported by Dark Knight
With Blade 7tsp and iPack icon Packs for
Windows 7 , 8 , 8.1 and for w10
Original Blade v1 for Windows 10 can be download here
https://virtualcustoms.net/showthread.php/77977-Blade-for-Windows-10-Creators-Update
Blade Green by Mr GRiM
By ミறѳѳղղįզվદ彡 in forum Mr GRiM's Windows 7 ThemesReplies: 7Last Post: June 12th, 2021, 04:01 AM -
Blade v2 for 1903 by Mr GRiM
By ミறѳѳղղįզվદ彡 in forum Moonnique's Ported ThemesReplies: 28Last Post: September 11th, 2020, 12:49 AM -
Blade Red by Mr GRiM
By ミறѳѳղղįզվદ彡 in forum Mr GRiM's Windows 7 ThemesReplies: 17Last Post: July 20th, 2020, 09:19 PM -
This is Blaze v1 Imported from Blade by Mr GRiM
By Donkuz in forum Themes by DonKuzReplies: 11Last Post: January 5th, 2019, 05:37 PM -
7tsp Mr.GRiM's Blade IconPack
By Lamia in forum Windows 8 IconpacksReplies: 7Last Post: August 24th, 2014, 05:51 PM
looking for help with...
