Thread: Visage
February 12th, 2019 01:58 AM #1
Visage v1.1
Visage
Theme For Windows 7
Updated to version 1.1
Screenshots updated for the new version
14.02.19
Changelog:
Fixed Group header selections not themed.
Fixed Trackbar colours.
Fixed colours for Trackbar Thumb buttons.
Reduced start menu transparency for better text visibility against bright backgrounds.
Fixed Tab header colours.
Tweaked the wallpapers.
Replaced all Listview & Treeview selection images.
(The tiled selection images were not working correctly in all areas of the OS)
Tweaked the control panel side navigation pane.
Remade the logon screens.
How To:
You'll need your system patched with either UXTheme or UXStyle & have Theme Resource Changer installed for the theme to apply exactly like it is in the screen shot.Visage v1.1.zip
Or
Instructions for changing the Logon Background manually is included in the Logon folder
Theme Extras:
Shellbrd (Branding) Image
System.cpl (Genuine) Image
An extra set of start buttons are also included with the theme along with instructions on how to use them.
Last edited by devillnside; February 14th, 2019 at 07:33 AM. Reason: Updated theme to version 1.1
Visage for 1903
By devillnside in forum Themes by devillnsideReplies: 4Last Post: September 11th, 2020, 01:38 PM -
Visage for RS5
By devillnside in forum Themes by devillnsideReplies: 7Last Post: February 19th, 2019, 10:42 PM
Custom Class Maps and...
