March 25th, 2011 03:25 PM #1
How to restrict the number of Login attempts in Windows 7
Most of the web services that require a login have a specified number of consecutive invalid login attempts allowed, after which you are restricted from further login attempts for a certain time period. This is to prevent a hacker from guessing your password by entering random characters continuously.
With the use of Local Security Policy, you can easily implement this feature in Windows 7 via the Local Security Policy. Do note that the Local Security Policy is only available in Windows 7 Professional or above versions by default.
To implement this security measure in your Windows 7, type Local Security Policy in the search box in the Start menu and press Enter.
Now in the LHS pane, select Account Lockout Policy from under Account Policies as shown below. Double click Account Lockout Threshold.
The Account lockout threshold security setting determines the number of failed logon attempts that causes a user account to be locked out. A locked-out account cannot be used until it is reset by an administrator or until the lockout duration for the account has expired. You can set a value between 0 and 999 failed logon attempts. If you set the value to 0, the account will never be locked out.
[attachment=5:2ban3koq]img1_thumb2.jpg[/attachment:2ban3koq]
Now select the number of invalid login attempts after which you want to lock the computer. Click OK.
[attachment=4:2ban3koq]img2_thumb2.jpg[/attachment:2ban3koq]
Next Windows will notify you that Account lockout duration and Reset account lockout counter will be set to default. You can either choose the default value or change it later. After you are done, click OK.
The Account lockout duration security setting determines the number of minutes a locked-out account remains locked out before automatically becoming unlocked. The available range is from 0 minutes through 99,999 minutes. If you set the account lockout duration to 0, the account will be locked out until an administrator explicitly unlocks it. If an account lockout threshold is defined, the account lockout duration must be greater than or equal to the reset time.
[attachment=3:2ban3koq]img3_thumb2.jpg[/attachment:2ban3koq]
To change the default values of the above mentioned settings, just double click the setting that you want to change and set the desired value.
[attachment=2:2ban3koq]img4_thumb.jpg[/attachment:2ban3koq]
The Reset account lockout counter after security setting determines the number of minutes that must elapse after a failed logon attempt before the failed logon attempt counter is reset to 0 bad logon attempts. The available range is 1 minute to 99,999 minutes. If an account lockout threshold is defined, this reset time must be less than or equal to the Account lockout duration.
[attachment=1:2ban3koq]img5_thumb.jpg[/attachment:2ban3koq]
Click OK once the desired values are set!
Now if anyone enter the wrong password for more than the set number of times, the user account will get locked out and the Administrator will have to unlock it.
Incidentally, to see your Current Account Lockout Threshold Setting, type ‘net accounts’ in an elevated CMD and hit Enter.
[attachment=0:2ban3koq]cmd-lockout-600x307.jpg[/attachment:2ban3koq]
Here you will see your current values.
Lee Whittington adds:
For users that do not have Group Policy there is still a way to set the values via the command prompt
Open an Elevated Command Prompt and use the following to set the values (replace X with the value you wish).
net accounts /lockoutthreshold:X
net accounts /lockoutwindow:X
net accounts /lockoutduration:X
Afterwards type in ‘net accounts’ to view the applied changes.
can you modify windows login screen?
By justin2556 in forum General Windows 8 CustomizationReplies: 3Last Post: May 31st, 2013, 12:01 AM -
How do I install a new login screen for windows 7?
By TechTheWorld in forum General DiscussionReplies: 3Last Post: February 20th, 2013, 06:43 PM -
Windows 7 login background problem after VC theme
By Exile in forum General QuestionsReplies: 8Last Post: July 8th, 2012, 09:25 PM -
Windows 7 Theme question ... Field Image number?
By Fastpop in forum Theme Building QuestionsReplies: 2Last Post: March 8th, 2011, 11:00 AM -
How to control and reduce the number of Dump Files Windows c
By razorsedge in forum News & ReviewsReplies: 0Last Post: January 16th, 2011, 09:26 PM
then it may be that your system uses locked files sometimes it also happens when using the ultrauxthemepatcher application the only way is to take ownership ExplorerFrame.dll.mun file manually...
Animation in explorer...
