Results 1 to 6 of 8
Thread: Clearing Windows Icon Caches.
September 6th, 2011 04:32 AM #1
- Feb 2010
- Cornfeilds of Indiana
- 2,528
- 21 Post(s)
- 298 Thread(s)
When changing Windows icons to custom icons, sometimes the Windows icon cache may not be refreshed automatically.
This results in some or all of the newly applied icons not showing up within the Windows interface.
This is a quick guide on how to manually refresh Windows icon cache.
Windows XP
Windows Vista
Windows 7
Windows XP
To clear Windows XP's icon cache, simply delete the file 'iconcache.db' from your profile directory.
This is usually found in: 'c:\Documents and Settings\[YOUR USERNAME]\Local Settings\Application Data\' *. The file will be automatically recreated when windows needs a new one.
* You may need to alter folder options in order to view the folders mentioned above.
To do this click on the 'Tools' menu, then 'Folder Options', select the 'View' tab and then tick 'Show hidden files and folders'.
(Don't forget to change this setting back to how it was after restarting to ensure your PC has the same setup prior to doing these steps mentioned in this guide.)
If you are still having problems with the icon cache file and deleting it does not help, a quick method for fixing these problems is to right-click on the desktop and choose Properties. In the Display Properties dialog box, click the Appearance tab. From the Item drop-down list, choose Icon. Click the up arrow in the Size box to increase it by one pixel. Click Apply, click the down arrow in the Size box to return the icons to their previous dimensions, and click OK.
Windows Vista
To clear Windows XP's icon cache, simply delete the file 'IconCache.db' from your profile directory.
This is usually found in: 'c:\Users\[YOUR USERNAME]\AppData\Local\' *. After deleting the file, restart your PC for the changes to take effect. The 'IconCache.db' file will be automatically recreated when windows needs a new one.
If you are still having problems with the icon cache file and deleting it does not help, a quick method for fixing these problems is to right-click on the desktop and choose 'Personalize' and then 'Display Properties'. In the Display Properties dialog box under the 'Colors' section, select 'Medium (16-bit)' (taking note of it's current setting) and click 'Apply', You might have to restart your PC depending on your setup. Now redo these steps but change the color back to its previous setting.
Windows 7
To clear the Windows 7 icon cache you must follow these instructions EXACTLY as they are given/shown.
1. Close all folder windows that are currently open.
2. Launch Task Manager using the CTRL+SHIFT+ESC key sequence, or by running taskmgr.exe.
3. In the Process tab, right-click on the Explorer.exe process and select End Process.
4. Click the End process button when asked for confirmation.
5. From the File menu of Task Manager, select New Task (Run...).
6. Type CMD.EXE, and click OK.
7. In the Command Prompt window, type the commands one by one and press ENTER after each command:
CD /d %userprofile%\AppData\Local
DEL IconCache.db /a
EXIT
8. In Task Manager, click File, select New Task (Run...)
9. Type EXPLORER.EXE, and click OK.
Windows 7 has changed how some icons are stored in the caches from earlier MS operating systems (some icons are now also stored in the 'Thumbnail-Cache')
To clear the thumbnails cache click start and in the start-menu's search-box type "Disk" (without the quotes), at the top of the start-menu 'Disk Cleanup' should be listed. Click 'Disk Cleanup' to run it, select your main system drive (usually 'Drive C') and then untick everything except 'Thumbnail Cache' (tick this if it's not ticked already) and hit OK.
UPDATE 05/25/2012
Rebuild Icon Cache Automated Bat File
I found this on another website
Thank you to Chris Sanders (aka Zidane24) for this updated BAT file version
Rebuild_Icon_Cache.7z
Unzip the file to your desktop
Double click to run
When prompted hit any key
You will be ask to do this twice
Next you will be asked if you want to restart your system. type y for yes and hit enter
Your donePlease Post In English OnlyDon't forget to leave Comments and Rep to the artist if you like or use their artwork.
Thanks VC Staff
7tsp MSI Dragon Red Icon Pack for Windows 10 19h1 - 21h2 and for Windows 11
By ミறѳѳղղįզվદ彡 in forum 7tsp Icon PacksReplies: 10Last Post: July 20th, 2023, 06:25 PM -
7tsp Windows 11 Icon Pack for Windows 10 19h1 - 21h2
By ミறѳѳղղįզվદ彡 in forum Moonnique's Ported ThemesReplies: 18Last Post: February 10th, 2023, 10:26 AM -
7tsp Windows 11 Icon Pack Fix for Windows 10 19h1-21h2 by Moonnique®
By ミறѳѳղղįզվદ彡 in forum General Windows 10 CustomizationReplies: 0Last Post: February 19th, 2022, 03:15 PM -
3D Objects Icon In Windows Explorer Windows 10 RS3
By roma1234 in forum Windows 10 Theme Help and SupportReplies: 2Last Post: January 6th, 2018, 02:59 AM -
clearing ALL adminstrative Service events at once
By AlphaOmega in forum General DiscussionReplies: 0Last Post: December 17th, 2015, 10:21 AM
Windows 12
